#1 |
Dumb question, what year range is this frame? I think it’s a 48’ passenger car frame based on the research I have done. I don’t have access to it at the moment.
Things outside of the 30’s are outside of my knowledge. Would this fit trucks too? A 41 pickup? |
#2 |
#3 |
Look for the serial number
#4 |
Will not fit a 41 pickup.
#5 |
#6 |
#7 |
1946 1948 (maybe 42) based on the staining from the rear body mounts. WILL NOT FIT 41 truck
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/ |
#8 |
#9 |
Here to compare.The furthest back cross member is straight on the '41.
#10 |
#11 |
Thanks for everyone's help, seems like it's a 41' frame. Too bad it doesn't fit the pickups.
#12 |
For a 41 pickup you would use the 40 passenger car frame or a 41 pickup frame.
#13 |
Sure lokks like a 41 car . I could use one if you don’t need it .
Gary |
#14 |
I don't need this frame, it can be acquired. It's in the Phoenix, AZ area.
#15 |
There is a 39 convertible sedan frame in Fountain Hills, AZ, at least there was a short time ago. It has upgraded shock mounts and needs a little bit of work but it’s on four wheels and rolls. I can get you the owners email if you would like.
