#1 |
Has anyone seen a brake rod with a bend in it. My 29 leatherback has a bent in the rear service brake rods on both side. Every manual I have looked at seems to say that they should be straight.
#2 |
Definitely should be straight.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#3 |
That was commonly done to shorten the rod a little.Not the right way,but if you needed to get to work you did whatever it took to get there and back.
#4 |
found the same on my 31 s/w, bought new ones...
#5 |
With all due respect guys above that happened because the rear brake rod hit the rear shock arm and shock adjuster. The car may have 32 or v8 shocks where the shocks are taller (thicker) than rhe A. It can also happen when the return springs on the radius rod are mounted not canted outward far enough. It is. Lose wnougj when they hit a large bump or have back seat load that upon the spring bounce tho can happen.
Look at your shocks and rod clearance and you will see. Yes many times rods get modified for length but in this case it appears to be a shock clearance issue. Doing service work and lots of brake work I see this more often than you think . Larry Shepard |
#6 |
#7 | |
![]() Quote:
Larry |
#8 |
Thanks guys, this is great information, and answers my questions! This is a great "go to" place for really good information.
#9 |
This can also happen if the rear brake arms are installed incorrectly causing the offset to be wrong.
