Old 05-20-2025, 05:25 PM   #1
Kgkatyag
Default Voltage Overcharging Issue
Hi Yall,
I'm working on an issue in my 1941 Super Deluxe. Its a 6V positive ground and the battery is Overcharging to 8.3V+. I opened the voltage regulator and it looked sort of burnt and was not adjustable, So I opted to get a new one.
The generator is also the 2brush non adjustable one.
I got the blue cover one (part #51A-10505) and installed it today, but I am having the same overcharging issue. The regulator is very very hot while running and still charging the battery to well over 8V
I tried turning out the screw on the bottom of the FLD relay, but no change.
I can push on the plate and disconnect the relay and the voltage goes down, so I dont think its stuck, but i'm stumped
I followed the instructions the reg came with to polarize the reg by touching the FLD to the BAT briefly and saw a small spark
Not sure where to go from here.
1st pic the old reg 2nd pic the new reg
File Type: jpg IMG_68596F00-5A80-4096-A45B-949B32B97B89.jpg (45.0 KB, 148 views)
File Type: jpg IMG_F21A2DF2-3B2A-406B-B7DE-C67116CED92E.jpg (28.7 KB, 146 views)
Kgkatyag is offline   Reply With Quote
