Old 05-12-2025, 03:57 PM   #1
oldspert
oldspert's Avatar
Default Painted or natural cast exhaust manifold
I think I know the result, but is it more desirable to leave the exhaust in natural cast or paint with high temp paint. Not going for show points but just a good looking engine for an every day.
Ed
oldspert is offline   Reply With Quote
Old 05-12-2025, 04:05 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Painted or natural cast exhaust manifold
Unpainted cast iron rusts, and its shape makes it difficult to clean, so if you want it to stay rust-free then some kind of protective paint is a good idea.
Old 05-12-2025, 04:23 PM   #3
Ray in La Mesa
Cast blast his temp is a good silverish compromise.
Ray in La Mesa is offline   Reply With Quote
Old 05-12-2025, 04:25 PM   #4
Ray in La Mesa
oops, Cast Blast high temp is good silverish compromise.
Old 05-12-2025, 05:09 PM   #5
DavidG
DavidG's Avatar
Check with your local powder coater to see what "natural" colors they offer in the way of high temperature coatings. It will outlast anything out of a can.
Old 05-12-2025, 05:45 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Sounds crazy but I use Slip- Plate. Once cured it is very durable. Gives a nice matte graphite sheen. Don't get it on a painted surface, you will never get it off.
Old 05-12-2025, 06:05 PM   #7
oldspert
oldspert's Avatar
Another thing, the intake and exhaust have been assembled and ground flat. I hate to take them apart just to coat the exhaust. Any thoughts? Also is there a reason to spot face the washer surfaces so they are flat to the mounting surfaces.
Ed
Old 05-12-2025, 07:43 PM   #8
nkaminar
nkaminar's Avatar
Those coatings that require a high temperature cure can be cured in your outdoor grill.
Blockhead, That is a beautiful engine. Did the plugs come with the copper tops or did you add those?
Old 05-12-2025, 11:02 PM   #9
Randy in ca
Randy in ca's Avatar
I've had good results from Calyx paste as long as the manifold is reasonably clean to begin with:
LINKS:
https://www.eastwood.com/calyx-manif...ting-3-oz.html
https://www.eastwood.com/garage/two-...ron-manifolds/
Randy in ca is offline   Reply With Quote
Old 05-12-2025, 11:28 PM   #10
Dodge
I used Cerakote, it holds up for years.
Dodge is offline   Reply With Quote
Old 05-13-2025, 07:49 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
I use stove black and it still looks good after many years of running.
File Type: jpg Hot Air Heater w Floor Register 429 kb.jpg (85.3 KB, 105 views)
Bob Bidonde
Old 05-13-2025, 08:32 AM   #12
eagle
eagle's Avatar
I'd check with those who've done thiers years ago, after lots of miles. Because when the coating starts to burn off or wear it then looks really ugly. It doesn't come off/burn evenly. I replaced mine with a repro about 10 years ago. Left it natural, it has an even rust color to it. I think it looks "right". However, my car is definitely a driver. My $.02
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-13-2025, 09:44 AM   #13
katy
katy's Avatar
Not as long as the washers are flat, don't have ridges from when they were stamped.
Old 05-13-2025, 10:15 AM   #14
Y-Blockhead
Haha, Busted. Those are Champion W18 Plugs with copper pipe caps that I polished to dress up the engine for car shows. "Faux" 3X's.
Thanks for the compliment.
Old 05-13-2025, 10:58 AM   #15
nkaminar
nkaminar's Avatar
Great idea. Probably keep curious fingers away from the running engine.
Old 05-20-2025, 07:16 PM   #16
Smokedtires
Smokedtires's Avatar
Very cool, love it!
Smokedtires is offline   Reply With Quote
Old 05-21-2025, 05:17 AM   #17
32Ford13
http://www.advancepainttech.com/
They have an incredible hi temp coating. Used it on three vehicles including my A. I think they do some coating for Snyders.
Nice people and great coating.
32Ford13 is offline   Reply With Quote
Old 05-21-2025, 09:30 AM   #18
JayJay
D - did you polish the brass spark strips too? 😉 Way too much time on your hands.
I have to admit to being hit with a dose of practicality. As cool as the original cap and strips are, a couple of weeks ago I installed a modern cap and wires to try to reduce RF interference with the CB I use on tours with the club. Too early to tell if it’s effective, haven’t been out on a tour with anyone to talk to yet.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 05-21-2025, 07:46 PM   #19
Y-Blockhead
I have been told the more than once...
Old 05-23-2025, 11:37 AM   #20
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I also used CALEX manifold dressing. Applied it on my installed manifold. It had an odor when hot for a time after application. Good results with a clean look!
Dick M is offline   Reply With Quote
