Old 05-12-2025, 01:16 PM   #1
Russell Reay
Russell Reay's Avatar
Default Pinion bearing preload
I just had the drive shaft shortened for my T5 conversion, and have needed to install and remove it with pinion attached a couple times. In the course of this exercise the big adjusting nut with punch location has been moved to the point that I don't dare install it again for fear of damaging the differential gear mesh. I am using a Mitchell pinion remove/ install tool. I think the bearing preload needs to be checked, but I have never done it. The red book describes the process, but presumes that the reader has a pile of loose parts. My pinion and bearings are all together in a big cluster with the two big nuts loose. Sorry, but operator deficiencies prevent photo attachment. How do I check the preload in this situation?
Russell Reay is offline   Reply With Quote
