Old 05-02-2025, 11:21 AM   #1
ShooksCustoms
Default 1941 Ford Super Deluxe headlight switch-parking lights.
Hello everyone long time follower, just registered.
Been working on lots of old girls so figured was time to join so I could get help on ones that are stumping me.
Should be easy one here.
1941 ford Super Deluxe. Brought to me for a few things.
My issue is head light switch. Was working fine about a month ago. When came back wires were disconnected. Plugged back in correctly, the parking lights on fender are on in the off position. Opened switch to check for damage. Looks good, but contact points do not make sense to me. Appears that they are getting power through contacts but shouldnt???
Anybody see something I dont?
ShooksCustoms is offline   Reply With Quote
Old 05-02-2025, 11:51 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 1941 Ford Super Deluxe headlight switch-parking lights.
[QUOTE=
Anybody see something I dont?[/QUOTE]
Old 05-02-2025, 01:42 PM   #3
JayChicago
JayChicago's Avatar
I noodled this out and think it should work if connected thus:
Using your top picture,
Top left terminal: taillights
Top right terminal: headlights
Bottom left terminal: parking lights
Bottom middle terminal: hot from circuit breaker (will feed tail and parking)
Bottom right terminal: hot from other circuit breaker (will feed headlights)
edit: In the off position switch will connect tail and park terminals, but no connection to a hot terminal
JayChicago is offline   Reply With Quote
Old 05-02-2025, 04:12 PM   #4
ShooksCustoms
Jay,
that did the trick. surprised the schematic was that unclear on this.
thank you for your help!!!
