#1 |
I have a '34 M40 that ran about 5 months ago (for prev owner) but now has no spark. Starter turns and distributor looks clean and newer, but wanted to ask if anyone has tried to add the 6v coil kit to an external coil.
The car has sapped most of my funds thus far and can't really afford to get a full dizzy rebuild at this point. My goal is to get it running by any means to be able to move the car around. Thanks, Jim So, I have a yellow 6v hot wire from the ignition but when I connect to the brown dizzy wire the voltage drops to 1.4. Not sure why.
"Whether you think you can, or think you can't- you're right." H. Ford Last edited by jchochole; 04-23-2025 at 11:41 AM. Reason: added pic |
#2 |
Is there a EFV8 Club Regional group close to you? Members there would be a great resource for you...
#3 |
I reached out.
"Whether you think you can, or think you can't- you're right." H. Ford |
#4 |
Just sent a response from RG#8 a few minutes ago. We will try to help him.
Ken
https://www.nirgv8.org |
#5 |
Clean the points
#6 | |
#7 |
There is a ignition resistor mounted to the inside firewall above the steering column. The resistor drops the voltage to the ignition coil. Usually to about 4V at the coil terminal but you can only read this voltage drop when the distributor points are closed and ignition switch is ON. When the ignition is ON and the distributor points are open you should have battery voltage on the coil terminal. There are several reasons the voltage is low. Bad battery, Poor wire and cable connections, dirty or pitted ignition switch, bad coil, bad condenser, bad resistor.
