#1 |
Rebuilding my 28 shift tower that has the E Brake located above the shifter. Trying to pull the racket plate off of it and it looks to only be held on by one large head slotted bolt.
So help me I can not seem to remove that bolt. It will easily spin about 1/4 turn then really locks up hard like theres a set screw on something holding it in place. Almost like the bushings are capturing the plate and the screw is almost trying to extract the plate and the bushing. Is there any trick to this or do I grab my impact screw driver? ![]() ![]() |
#2 |
Is the ratchet damaged? Do you really have a need to remove it?
#3 |
Removing it to clean and refinish the tower. I was also going to clean and nickel plate the rachet plate.
#4 |
Answer is no. Its just the screw. Just used a large screwdriver with a wrench on the handle to turn it. Just posting the follow up in case anyone searches for this in he future.
#5 |
An impact screwdriver, that you hit with a hammer, is a good tool to remove large screws such as this when a normal screwdriver will not work.
#6 |
