Old 04-22-2025, 07:03 AM   #1
41SupDelux
Default Mismatched Hinges/Trunk Deck Gap
Good morning, friends,
1941 Ford Super Deluxe Fordor
I have a gap in the trunk lid/deck on the upper left corner and it appears to be caused by a hinge that doesn't match the other, both by visual inspection and measurements. What should I do? Modify the hinge? Buy new hinges? Thanks!
41SupDelux is offline   Reply With Quote
Old 04-22-2025, 08:08 AM   #2
BoxCar Tom
BoxCar Tom's Avatar
Default Re: Mismatched Hinges/Trunk Deck Gap
Bondo, Only Kidding
Back the car into a hard object, Only Kidding
Wear Sun Glasses, Only Kidding,
Put an ESSO Tony the Tiger Tail there, Only Kidding
Seriously, take both hinges off the car, identify the differences, modify accordingly (nothing to loose), go slow, small adjustments seem to have big effect. Also look at how - where the hinges are attached, any differences? If modification/adjustment doesn't work, look for a replacement hinge.
Back in December I installed a NOS deck lid in my coupe, perfect (tight) gaps. Opened it last week, rubbing in two spots (paint loss), 40 degree temp change to blame. Good luck,
BoxCar Tom is offline   Reply With Quote
Old 04-22-2025, 10:58 AM   #3
petehoovie
petehoovie's Avatar
Old 04-22-2025, 03:50 PM   #4
Ggmac
It looks like the hinge on the right has a tear in the metal . It could be your gap .
Ive got a few tudors I’ll take photos of . I have a 46 that has very similar hinges , I’m not sure they interchange but if they dont that could be your gap . I’ll take photos of the 46 also .
Ggmac is offline   Reply With Quote
Old 04-22-2025, 04:09 PM   #5
Ggmac
I just took some quick pics . I sent you a pm . Look up top right under your name if you didnt already know where to look .
Im not to tech savy so emails are the only way I can send pics.
Gray
Old 04-22-2025, 06:14 PM   #6
Ggmac
Never mind , mine are Tudors
Old 04-23-2025, 03:12 PM   #7
alchemy
alchemy's Avatar
Yeah, it looks like cracks in both hinges. I think spacers between the body and the hinge should make the lid sit closer to the body. Basically spacing the pivot point closer to the center of the car.
alchemy is offline   Reply With Quote
Old 04-23-2025, 03:51 PM   #8
Ggmac
All 4 of mine 3 41s and a 46 have a spacer .
