Old 04-12-2025, 05:19 PM   #1
CFreitas
Default Rear hub bolts size
I need to replace the rear hub bolts of my Ford and acquired bolts A-1118 for my suite cast iron drums.
Now I have a problem, the hub bolts don't hold on to the drum, they have a tangentially smaller diameter.
I attach a photo, where you can see that the originals (right side) have a square fitting (also in the drum) and the new one (on the left) has a rounded triangle!
I will be grateful if someone can help me.
CFreitas is offline   Reply With Quote
Old 04-12-2025, 05:46 PM   #2
JayJay
Default Re: Rear hub bolts size
The description by Snyders states that they need to be swedged onto the drum. If you have not swedged them, then this would explain why you are having the trouble you are. Typically a 40-ton press is recommended for swedging these.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 04-12-2025, 05:52 PM   #3
mercman from oz
mercman from oz's Avatar
Old 04-12-2025, 05:53 PM   #4
mercman from oz
Old 04-12-2025, 05:59 PM   #5
Bruce of MN
Bruce of MN's Avatar
To help with translation, the term is "swaging".
The tool to use is https://www.snydersantiqueauto.com/p...6156&cat=41753
Bruce of MN is offline   Reply With Quote
Old 04-12-2025, 06:29 PM   #6
JayJay
I agree. I don’t know where “swedging” came from, but it seems to be in use these days.
JayJay
Old 04-12-2025, 08:09 PM   #7
bobbader
Swaging is basically a process similar to riveting where a hydraulic press brings a hollow tool down over the threaded portion of the stud. When the tool hits the "collar" portion of the stud it "peens over" a lip (or ring) around the circumference of the collar to hold the stud tight inside the mounting holes in both the hub and drum. This basically mates the hub and drum into a single unit that cannot be separated unless that newly formed lip is cut off and the studs removed. As previously stated, this is an operation for a machine shop with a 30-40 ton press, the proper tooling to "back" the studs and create the lip, and, preferably, a person with experience doing this operation. If not done properly, the hub and drum can both be ruined.
bobbader is offline   Reply With Quote
Old 04-12-2025, 08:21 PM   #8
Ruth
wasn't there a thread recently about someone using 'regular' serrated wheels studs?
Ruth
Old 04-13-2025, 03:02 AM   #9
CFreitas
Precious help.
Who knows, knows!
Thank's
Old 04-13-2025, 08:34 AM   #10
larry harding
try find someone in your area that has the tools and experience doing this.
i have a 94 year old friend who has been doing these lug bolts for years. he is teaching me the art of swaging the lug bolts. it is quite a process, and you can crack the cast drum in the process. look at the old original bolts and you can see where the have been swaged. you also need to use a special shell cutter to trim the old swage before pressing out.
larry harding is offline   Reply With Quote
Old 04-13-2025, 09:27 AM   #11
JayJay
FWIW, I use a drill from the back side to remove the heads of the studs, then tap them out. It does require that you set your drill up EXACTLY on the center of the stud you are drilling. I use my small vertical mill, but you can use a drill press as well. Here’s the fixture I made to set the hub on.
JayJay
Old 04-14-2025, 06:37 AM   #12
CFreitas
Larry can you please post photo of the shell cutter?
I'm looking for your photo JayJay and I'm trying to understand how to use the tool you designed. Is the intervention done from the outside of the drum or from the inside?
Old 04-14-2025, 08:12 AM   #13
Joe K
Joe K's Avatar
The shell cutter CAN be a small hole saw. The object being the ID of the hole saw is slightly larger than the OD of the threaded portion of the bolt.
The only problem you might encounter using a hole saw is the "depth" required to stay above the length of the stud.
Some use a "hollow mill" which given a Bridgeport Mill available, would be the way to go.
The vendors (IIRC) sell a saw/mill/cutter which will do this with power tools. Check out https://www.snydersantiqueauto.com/p...htm?pid=976151
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 04-14-2025, 10:49 AM   #14
JayJay
Drum mounts upside down (inside of the drum facing upwards) with three of the five wheel studs inserted into the vertical round stock that is welded to the flat plate. Drill from the back side.
Setup is by centering the drill to one of those three round pieces, then clamping the table securely. That way you will always be in the center of the stud you are drilling.
Only drill deep enough to free the head of the stud, you don’t want to risk drilling into the hub.
Ignore the three leveling screws, those are for another thing I use that plate for.
JayJay
Old 04-14-2025, 11:04 AM   #15
J Franklin
J Franklin's Avatar
I think it would be best to find a local truck or machine shop, or Randy Gross, to do that type of work.
J Franklin is online now   Reply With Quote
Old 04-14-2025, 11:24 AM   #16
JayJay
I don't set the new studs. I made this to harvest hubs from old steel drums so that I could sell the hubs at swap meets. I made it from steel I had on hand rather than spend $100+ on a swedge cutter.
If you need to have new drums installed on hubs, Randy Gross is your guy.
JayJay
Old 04-14-2025, 01:12 PM   #17
CFreitas
I am very grateful for your support
I have a very small problem: I leave in Lisbon (Portugal - Europe) and finding someone who really knows about Ford A is very difficult and my car is 200km far away (my father´s home).
On the other hand, importing directly is a bit complicated due to costs and bureaucracy. It is almost easier to go there and bring it!!!!
For example, I needed a "Speedo Shaft Retainer" (A17274) which I can't find in Europe and in the US it costs $2. I would have to pay at least $100 for shipping and customs service, not including taxes (vat and import tax)...
Old 04-14-2025, 01:21 PM   #18
JayJay
Sounds like a good excuse to visit the USA.
JayJay
Old 04-14-2025, 01:36 PM   #19
J Franklin
J Franklin's Avatar
You must have a truck repair shop or machine shop in Portugal. This is not a new type operation, or just for a model A. Those type of shops should be able to do it. Don't overthink this.
Old 04-14-2025, 01:51 PM   #20
CFreitas
Finding seniors who understand what they are doing is very difficult, and the very few that exist, in any specialty, are unable to respond to requests and are very expensive!
There are some who accept jobs, but as soon as you get there you run away straight away, they are opportunists
(today a car mechanic only knows how to turn on a computer, order the parts it indicates, and there is no guarantee that he will be able to follow the instructions to replace the parts...)
