Old 04-08-2025, 03:58 PM   #1
jimTN
Default 34 front spring
My 34 sets to low on the aftermarket spring that came with it and I am rehabbing a original 33/4 front spring. Car is a sedan and book calls for 12 leaves and I only have ten. So far I have wire brushed with a grinder and next will go thru with a grinder to smooth the indentions at the end of some of the springs. Then will paint and coat with Slip Plate. Can anyone recommend a trusted source of used parts where I could find the top two leaves I need.
jimTN is offline   Reply With Quote
