Old 03-20-2025, 12:16 PM   #1
signsup
Default Radiator air flow sheet metal on 1942 Mercury question.
Got my restoration guide for the 41/48 Fords and it mentions on the 42 Mercury some sort of sheet metal that directed air flow under the hood through the radiator. I'm picturing some sort of sheet metal screwed into the front hood support area, along the inner fender sheet metal and attaches or lays on top of the radiator to keep air from coming in through the grill and being dispersed before it gets to the radiator. But no pictures in the guide as to my envision.
Any one confirm this set up, have a pic or any additional guideance? I cannot feel any attachment holes in any of these areas I mention and my radiator is a reproduction, so nothing on it.
Any guideance appreciated.
signsup is offline   Reply With Quote
Old 03-30-2025, 06:54 AM   #2
38 coupe
38 coupe's Avatar
Default Re: Radiator air flow sheet metal on 1942 Mercury question.
I am not familiar with 42 Mercuries, but the 42-48 Fords have a sheet metal piece that encloses the area in front of the radiator and goes to the top of the radiator core. The top tank is exposed. You can see a picture of one here: https://cdn.dealeraccelerate.com/bag...luxe-sportsman
Old 03-30-2025, 08:08 AM   #3
42merc
42merc's Avatar
The sheet metal deflecter for '42 Mercury & Ford is unique to 1942.
It is a piece bolted to the hood that fills the gap between the top of the radiator and the hood.
PM your Email & I'll send a photo.
42merc is offline   Reply With Quote
Old 03-30-2025, 09:50 AM   #4
1942deluxe
1942deluxe's Avatar
My 42 Ford was missing that piece. I've never seen it for sale anywhere and I've looked.
1942deluxe is online now   Reply With Quote
Old 03-30-2025, 10:18 AM   #5
signsup
Now that I know what to feel for, it appears that the side mounted sheet metal is well aft of the headlight buckets and deflects air from the inner fenders to the radiator mounting braces, so pretty flush on the sides. And, what I was calling a hood brace that I drilled a small hole in one side for my Bubba hood support to latch into is actually the top air dam. I don't know how tight a fit this will be to my reproduction radiator, but my game plan is to install the radiator, close the hood and use my fibre optic camera on a long rod to see under the hood through the grill and see how close this dam gets to my radiator. doesn't have to be air tight, but needs to be close. Don't know if it will come down in front of the radiator or on top, I suspect the former as I do not feel a cut out for the radiator cap. The military vehicles of this era would use some sort of thick felt strips stapled to radiator shrouds to keep air flow to a maximum.
So, I've got all the pieces, I think. Thanks for the guideance.
Old 03-30-2025, 10:41 AM   #6
1942deluxe
1942deluxe's Avatar
Glad to hear all the pieces are there. Took a quick look at the 1944 parts book and the piece on the hood is different for Ford and Mercury. P/N 21A-16613 for Ford and 29A-16613 for Mercury. Liquidmatic drive used 29AS-16613.Don't think any of those exist!
Old 03-30-2025, 10:51 AM   #7
signsup
if it would help the hobby, I am more than happy to not only take pics and ost, but it appears that only three small nuts hold the shield in place, one at each side on the hood lip and one using a hood top center trim strip bolt and nut, so not a big deal to remove and take pics and measurements if it would help.
Old 03-30-2025, 11:35 AM   #8
1942deluxe
1942deluxe's Avatar
[ATTACH]563805[
Photo of a 42 Mercury owned by "Todd" Sloan, who was the Ford dealer in Primghar Iowa from 1935-1954. His son had a 1942 Ford convertible until he went to serve in WWII. I owned the dealership 1996-2004 until Ford bought me out and closed the point after 90 years.
Old 03-30-2025, 05:04 PM   #9
signsup
So, here is the air dam off my 42 Mercury Town Sedan. Held in place with two slotted bolts through a hole in the underside hood lip and picks up the hood center trim strip first bolt and nut. All the rubber is gone and the staples remain. Have no idea what shape or form the rubber would have been, but the gap between the top of the deflector and the center mounting bracket appears to be about 1/4" thick. For future reference. Aproximately 27" wide.
Old 03-30-2025, 08:30 PM   #10
rich b
rich b's Avatar
Found a picture of a '42 Ford hood I had, shows the piece and where it is bolted to hood; but can't see any rubber.
rich b is offline   Reply With Quote
Old 03-30-2025, 08:33 PM   #11
petehoovie
petehoovie's Avatar
Old 03-31-2025, 07:32 AM   #12
1942deluxe
1942deluxe's Avatar
Signsup and Rich, thanks for posting those photos!
Old 03-31-2025, 09:21 AM   #13
signsup
Rich, by the wire staples left in my air dam, it appears that some sort of rubber or material was attached to the top to prevent air flow from passing between the dam and the hood. Only about 1/4" gap, so perhaps a bit of over kill. Do you see any wire staples or holes for them in the top of the air dam on your hood? Perhaps a Mercury thing? There was one small remnant of a very brittle hard rubber piece left on mine, so I'm presuming rubber and not a cloth wind lace or other fabric due to the heat. If I can't find any difinitive reference, I may just roll some inner tube rubber and reuse the wire staples. Anything thicker or denser, to me would be difficult to wire staple through.
Old 03-31-2025, 03:23 PM   #14
Ggmac
I’ve used garage door bottom seal in applications similar to this . It’s inexpensive, durable and easily worked .
Ggmac is offline   Reply With Quote
Old 03-31-2025, 04:56 PM   #15
meric42
meric42's Avatar
I hunted for years to get two of these for my '42 Sedan Delivery's. Nearly as hard to find as the spare wheel hold down bracket for a Sedan Delivery. All made out of unobtainium, it would seem :P
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
