#1 |
7-tooth steering box. I have it pulled apart and cleaning it and I can not remove the nut- oil seal retainer in the steering lower bearing assembly.
The plate with the 4 hold for the mounting bolts is loose enough it can rotate a bit so if I clamp up on it - just spins the central body of the assembly. I tried using something in the oil hole to try and hold the body but it still spins out of a vise. Any tips for loosening it? I don’t feel like buying a new assembly for $100+ ![]() ![]() ![]() |
#2 |
![]() ![]() ![]() Also re-staked the plate on the assembly. You can see the small dots in the last photo. |
