#1 |
I'd like to add two aftermarket temp gauges, one for each head. My stock gauge also works. Is there a way to keep the stock gauge working If I add aftermarket too? I assume I can't get the stock gauge to work on an aftermarket sender or vice versa.
I'll be adding voltmeter and oil pressure too. stock 6 volt system. Thanks for any help. 52 customline 8ba
52 Ford Customline Fordor Last edited by Hoodooman; 03-15-2025 at 10:43 PM. |
#2 |
My understanding is that the stock temp gauge is proprietary and works using an electromechanical process. It has a small set of contact points that open and close sending a signal to the gauge. I don't think it would be synchronized to work with the modern gauges available today. Most of the mechanical temp gauges currently available use a capillary tube filled with ether and are calibrated to work the gauge through expansion and contraction of the gas in the tube. Electrically operated gauges would need to use the sender that comes with them and wouldn't work with the stock gauge.
Give us some feedback if you have any success to the contrary. |
#3 |
Just put the new gauge senders in each of the heads, mechanical gauges not electrical. That's the way i have it all three gauges read the temp and no wiring problems.
#4 |
may be eaiser said then done if its not an 8BA
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#5 |
Even with an 8BA, it's not an easy task unless you don't want a heater. Even then, you would probably only use the one-terminal Ford sender in the right head. There would then be one aperture on each head to accept the senders for the aftermarket gauges. The temperature senders are all quite bulky, and I have never seen a "T" fitting large enough to accept them. I'm sure you could "monkey" something up that would work, but I'm betting it wouldn't look very good. I think you are taking this "belt and suspenders" approach a little too far.
Better to do what I and several others have done. Remove the dual post Ford sensor from the left head and move the one post sensor to the to that empty port and hook it up to the lead from the Ford gauge. Put the sensor from an aftermarket gauge in the now empty port in the right head, run the capillary and mount the gauge. It works fine. Even though the Ford cooling system is separated in the engine, everything mixes in the radiator, so the overall temperature in the engine stays pretty consistent. And you get to keep your heater, which should be nice in the Blue Ridge Mountains. |
#6 |
#7 | |
![]() Quote:
#8 |
I’ve got a “Y” in the back port on the passenger side head with a mechanical sender in it. Only tells me what the one side is doing though.
Factory gauge in the dash is still operational as well. |
#9 |
Looks like I'll likely go with just one aftermarket and keep my stock unit working too. Thanks guys! I have the ol girl running pretty good now!
52 Ford Customline Fordor |
