#1 |
Found these in my boxes of Model A parts...??
2024 Bronco Sport, 2016 Roush Mustang, '53 Mercury M100 pickup, '86 Mustang SVO, '31 Model A Coupe "If there's no plan, what could possibly go wrong...??" |
#2 |
the silver one is a seal driver I believe, black is valve guide remover for split guides
As Carroll Smith wrote; All Failures are Human in Origin. |
#3 |
Seal driver for the seals inside the rear differential housing. Should be threaded 1/2-NPT to screw onto a piece of pipe.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#4 |
The valve guide remover is used with the spring removed, but (by necessity since it is "captive") the valve is in place - but lifted "up" as high as it will go.
THEN the valve guide remover is placed "around" the valve stem with the small part down and the valve "backside" seats onto the larger top of the guide remover. The valve and remover are then lowered until the remover "touches" the top of the valve guide - and the top of the valve is "tapped" with a hammer. Not too hard lest you damage the valve. The guide is pushed down into the valve spring chamber. The valve guide remover is reproduced and they're quite functional even in the repops. Joe K
Shudda kept the horse. |
#5 |
![]() I highly doubt I'll ever use these, will be donating to the local Model A club (if they the don't already have them in their tool inventory).
