#1 |
I have an issue with the lights on my 36 ford sedan, sometimes I find after cruising the lights are on, no matter what i do with the switch on steering wheel they will not switch off, I had this issue at a show where the park light was on. If I disconnect the battery then reconnect they are off. I have a batt disconnect terminal now. Any pics of where the light switch is housed and what it looks like would help. Any advice? I am in Australia, car is RHD.
#2 |
The light switch is at the bottom of the steering column. Its held in place by a wire bail, and my guess is that wire bail clip has come loose, and the switch plate inside has moved.
Its an easy thing to check out, unclip the bail, and see that the plastic switch plate is in position, and all wires are attached. There is a square notch that locates it |
#3 |
Also, you need to twist the can to pull it off. look at the stamped marks to see which way...I forget!
#4 |
And be careful. Unless the wiring has been replaced recently, it is probably old and very brittle.
#5 |
Thanks all, I am on it now. Love this group
#6 |
