Old 03-03-2025, 07:37 PM   #1
OldMercs
OldMercs's Avatar
Default Advice on cleaning up for new gaskets
My intake manifold is in the paint shop. Now I need to prep the heads for new gaskets. What's the preferred method to insure a proper seal first time?
I was going to attach pictures but they're in .heic format. I'll try again tomorrow.
OldMercs is offline   Reply With Quote
Old 03-03-2025, 10:06 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Advice on cleaning up for new gaskets
I'd likely wad up some paper towels and place them in all the intake & coolant ports to help prevent debris from falling in. With a good razor blade scraper remove as much old gasket material & sealer as possible. Then wipe down the gasket surfaces with brake clean or carb cleaner. Lastly and carefully remove the wadded paper from the ports in the heads.
The intake gaskets are right & left handed, double check their fit. Notice the gasket in this example photo is on the incorrect head.
dmsfrr is offline   Reply With Quote
Old 03-04-2025, 06:37 AM   #3
OldMercs
OldMercs's Avatar
Thanks, looks like an easy thing to overlook.
Old 03-04-2025, 10:40 AM   #4
Ford blue blood
Ford blue blood's Avatar
FE head gaskets are another "easy to foul up" thing that lots of folks miss.......
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 03-04-2025, 10:49 AM   #5
dmsfrr
dmsfrr's Avatar
Aren't most Ford head gaskets that way? The Y-block head gaskets are easy to put one on backwards and I think the Windsor engines can have the same issue.
Originally Posted by OldMercs View Post
My intake manifold is in the paint shop. ...
I almost forgot, if it's not too late.
To help keep the new paint nice there are intake gaskets made with a smaller hole for the exhaust crossover, so it doesn't get as hot and burn the paint. Originally made for 'truck' applications but they work very nicely on all other Y-block engines too.
Examples in the bottom half of this photo.
Old 03-04-2025, 08:00 PM   #6
paul2748
paul2748's Avatar
Sealer around the intake ports is not needed, but you should use some sealer around the water ports.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-04-2025, 10:14 PM   #7
miker98038
miker98038's Avatar
On your other post on the intake, there’s a comment on checking alignment. When everything is clean, make sure to do that. Before the gaskets go in. Just in case the manifold was milled to fit block or head work in previous machining. It’s probably fine, but better now than chasing a vacuum leak. Lots of times an aluminum manifold will give a bit, but cast iron doesn’t go anywhere.
miker98038 is offline   Reply With Quote
