Old 03-02-2025, 11:34 AM   #1
JayMan!
Question radiator overflow or make up tank on 1936 Ford Coupe
Recently I purchased a 36 Ford coupe and discovered there is an overflow tank mounted on the firewall. One of the plastic tubes from the bottom of the tank is connected to a port at the bottom of the radiator. The second tube from the top of the tank goes to the ground. I know the 36 Fords did not have overflow tanks so I was wondering if this tank may have been added as a coolant make up reservoir, and is the reason the tube coming out of the bottom of the tank is connected to a port added to the bottom of the radiator. Has anyone ever heard of this? Thoughts?
JayMan! is offline   Reply With Quote
Old 03-02-2025, 09:45 PM   #2
JayChicago
JayChicago's Avatar
Default Re: radiator overflow or make up tank on 1936 Ford Coupe
Never heard of this. Don't see how that can function. Any chance you can talk to whoever did that, find out what he was thinking?
JayChicago is offline   Reply With Quote
Old 03-02-2025, 09:48 PM   #3
tubman
tubman's Avatar
Is it a pressurized system?
Old 03-05-2025, 01:49 PM   #4
JayMan!
I don't know when this was added and I don't know the previous owner. I don't think it is a pressurized system. The radiator and cap appear to be the original. Appreciate input on this to understand why this was added.
Old 03-06-2025, 11:43 AM   #5
JayChicago
JayChicago's Avatar
Been waiting for someone to offer an explanation for this Rube Goldberg tank, cuz I can't think how this could do anything to help the cooling system.
I would suggest you wait for warm weather, see if it has an overheating problem. Then remove all that stuff and see how it acts without the tank.
Old 03-06-2025, 12:07 PM   #6
KiWinUS
KiWinUS's Avatar
I have run a coolant recovery tank on my stock 36 for many years with both a stock radiator and a Walker pressurized radiator. So long as caps seal correctly recovery system works great with both pressurized or non.
KiWinUS is online now   Reply With Quote
Old 03-06-2025, 12:37 PM   #7
Brian
Brian's Avatar
Yeah Tony, I run one in my 35, but am reluctant to post about it on here on account of several members who vehemently oppose this modification.
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 03-06-2025, 12:47 PM   #8
KiWinUS
KiWinUS's Avatar
Haa Haa too funny Brian as I typed my reply and hit enter I said to my wife. Now let the experts chime in. lol.
Old 03-06-2025, 02:04 PM   #9
JayChicago
JayChicago's Avatar
But I bet you guys don't have the plumbing this way:
"tube coming out of the bottom of the tank is connected to a port added to the bottom of the radiator."
Old 03-06-2025, 03:32 PM   #10
KiWinUS
KiWinUS's Avatar
We don’t Jay. Ours is in overflow. Is your tank mounted higher than top of radiator? Otherwise it would seem water should run out. Your system is not pressurized then. After thinking about it bet yours is connected to stock radiator overflow tube at bottom of radiator. Jay look closely again at where your hose attaches at bottom of radiator. I’m guessing it is connected to the stock overflow tube that runs from bottom of radiator up into your top radiator tank. If so that is exactly how mine is with stock radiator and I believe Brian’s also.
Old 03-06-2025, 04:13 PM   #11
JayChicago
JayChicago's Avatar
Good thought, KiWi. Then this would all make sense.
Old 03-06-2025, 04:17 PM   #12
KiWinUS
KiWinUS's Avatar
Yes I got halfway through writing that last post and said to myself. That’s how mind is that’s absolutely correct.
Old 03-06-2025, 04:18 PM   #13
KiWinUS
KiWinUS's Avatar
You can move that style tank out of sight if you want and it will still work.
Old 03-08-2025, 07:17 AM   #14
Mart
Mart's Avatar
The connection at the bottom of the radiator might be where the overflow tube comes out.
Old 03-08-2025, 11:20 AM   #15
JayChicago
JayChicago's Avatar
Yes, Mart. That is the point KiWi was making in #10: "look closely again at where your hose attaches at bottom of radiator. I’m guessing it is connected to the stock overflow tube that runs from bottom of radiator up into your top radiator tank."
That would make sense out of all this. Then the Original Poster just has the typical added overflow tank.
