Old 02-25-2025, 02:22 PM   #1
TimTheEmchanter
Question Engine Tight After Installing Piston
Hi All,
I’ve been working on a rebuild of an engine and went through and check the main bearing clearances and everything was generally okay, inspec. I started check rod bearing clearances and they actually seemed better than the mains, and I started installing them #4 -> #1. I would check rotation on the crank with pistons in, there was a good amount of resistance, maybe 35-40ftlbs. I install the first piston and the motor completely locks up. Shim it twice with .003 on both sides and still locked up. Not sure what to do at this point? Keep shimming or maybe shim the front main? The piston moves up and down in the cylinder just fine when I disconnect from the crank so I’m confused at this point and need help lol
TimTheEmchanter is offline   Reply With Quote
