Old 02-19-2025, 01:24 PM   #1
rfitzpatrick
Default Wire Corrosion
While inspecting my ignition, pulled the coil wire from the distributor, pushed back the nipple and the medal connection fell right out!! Thought this area was sealed somewhat-- corrosion reached quite a distance --- what can I do in the future to prevent wire corrosion?
TKS
rfitzpatrick is offline   Reply With Quote
Old 02-19-2025, 01:48 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Wire Corrosion
Dielectric grease prevents corrosion but it does not conduct electricity.
Seth Swoboda is offline   Reply With Quote
Old 02-19-2025, 02:07 PM   #3
Joe K
Joe K's Avatar
No-Al-Ox is a conductive grease that is usually used with aluminum wiring.
For a while houses wired with aluminum wire were burning down due to "hot spots" at the wire-nuts. Aluminum "skin oxidizes" which is effectively an insulator. No-Al-Ox solved that.
But it also works well on ANY electrical connection.
I use it under the clamps on the battery post. Never had the "white oxide."
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-19-2025, 04:21 PM   #4
nkaminar
nkaminar's Avatar
I will second what Seth said.
Old 02-19-2025, 09:19 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
I use Dielectric grease on all electrical connections, including in light sockets to prevent corrosion.
Old 02-19-2025, 10:50 PM   #6
CT Jack
CT Jack's Avatar
rfitzpatrick
I am assuming you live in Florida in the Coral Springs area which is very close to the coast. The moist salt air is probably acting like an electrolyte and when combined with a voltage source it can be very corrosive. Using a dielectric grease is a good idea.
CT Jack is offline   Reply With Quote
Old 02-20-2025, 08:20 AM   #7
rfitzpatrick
[QUOTE=CT Jack;2370767]rfitzpatrick
Yes, I do live a few miles inland. Was shocked to discover the corrosion on a relative new harness tho. I'm cleaning and using that item mentioned. I thought the spark plug harness nipples were sealed, somewhat
TKS
Old 02-20-2025, 09:42 AM   #8
Kurt in NJ
Kurt in NJ's Avatar
If there is a gap that spark is jumping between the wire and connection there will be corrosion
Old 02-20-2025, 11:13 AM   #9
katy
katy's Avatar
AKA Penetrox
