#1 |
Taped all the holes off, hooked up 5hp. Shop vac to water inlet. Remove tape off of 1 hole, scratch around with a screwdriver. Afterwards I ran the magnet into each hole. Results just a tiny amount of debris cam out.
Inside of shop vac tells the story. |
#2 |
I've attached a piece of speedometer cable to my drill motor, turned it CCW, down thru the water openings in the block, and with the block downside up, rooted around in the block. Gravity does the rest.
#3 |
So much better to have in the shop vac instead of plugging up the tubes in the top of the radiator!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#4 |
I use a piece of lawn mower control conduit with a hand drill. Be hind cyl. 4 is the area to work on heavily. Lots of air then water and air. You would be amased the pile that comes out!!!
#5 |
when I cleaned out the water jackets of my unrestored '31 Coupe several years ago I got a peanut butter jar full of scale.......
our next Model A has arrived.... ![]() |
#6 |
#7 |
A much easier way to do it without tools is using RUST911. Drain the cooling system and refill with rust 911. Leave it in fir 24 hours. You can drive the car with the RUST911 in it. Drain and you will notice that the clear RUST911 is now black. Repeat the procedure till it drains clear. The rust911 will dissolve all the rust from the cooling system. It even dissolves the rust flakes in the radiator. https://www.amazon.com/Rust911-16-ga...59&sr=8-1&th=1
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
