#1 |
I converted my 1937 to 6-volt halogen lights. What kind of generator are you guys using with a fan on the generator? Something that will handle the additional load of the halogen headlights. The car is otherwise completely stock.
#2 |
I know it is a little late, but going with LED's seem to be the way to go. Less draw than regular lights.
#3 |
I swapped halogen headlight bulbs into a 37 sedan years ago. I adjusted the generator to just keep up with the headlights when they were on, then added a Fun Projects regulator. The Fun Projects regulator didn't like the output of the V8 generator and died in a couple years. I swapped to a regular cut-out and replaced the third brush with a regulator built by a man who has since ceased production. The generator itself never had a problem with any of the above. I since sold the car to a friend of mine who has made no changes to the generator or lights, and he is having no problems either.
I prefer halogen bulbs over LED bulbs. The halogen are full spectrum light without the weird shadows you get with LED, and they project further down the road than the LED bulbs I have seen for 35-39 Fords. |
#4 |
I tried the LED bulbs from the guy everyone recommends. They would not fit my stock Ford headlight wiring harness. We went back and forth twice; I sent him a photo of the sockets and he told me I had Chrysler headlight sockets. At that point I politely moved on.
#5 |
Well, if comes down to the continuous AMP draw of the bulbs? Do you know what it is? Do you have an inductive amp meter than can measure it?
What I did on my 32 cabriolet was take a 34 generator and I sent it to E.J. Whitney for their alternator conversion. The create a bit bigger middle section, graft an alternator into it, add a cutout that looks completely stock and it works fantastic. It has good bearings in it so I've had no problem with the 32 fan setup, it looks stock and it puts out the juice - exactly what I wanted. I've been running the unit for about 7 years - has worked flawlessly. They are good folks as well - highly recommend them. The unit isn't cheap - but you definitely get what you pay for! https://ejwhitneyco.com/automotive.html |
#6 |
#7 | |
![]() Quote:
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
#8 |
I used a 6 volt alternator concealed in a generator housing made by E J Whitney. It has the fan mounted to the generator, looks stock,works great. They offer several options, voltage, pos or neg ground etc.
I've used it with both halogen and LED. LED is the way to go. EJ Whitney Company 714-773-1611 I dealt with Tom, great guy! |
#9 |
I could adjust the 3rd brush on my generator to put out more amps. I don't want to cook my battery though.
#10 |
You need to backup and first figure out what the AMP requirements/draw is for the lights you want to run. If your generator isn't putting more than that out, then you'll be drawing down your battery. As far as the generator cooking the battery - that will depend on the type of cutout or voltage regulator you have. Also, you don't want to overwork the generator . . . bad things can happen when they get too hot.
