Old 02-09-2025, 04:25 PM   #1
Greg Jones
Greg Jones's Avatar
Default Care and Feeding of Trico Vacuum Wipers
I have a chrome Trico vacuum windshield wiper in my 31 Victoria. Is there general maintenance that a person should do with these vacuum wipers? In other words, lubrication, cleaning, all that sort of thing.
Greg Jones is offline   Reply With Quote
Old 02-09-2025, 04:50 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Care and Feeding of Trico Vacuum Wipers
I have seen a page showing how to lube a wiper motor. It shows sucking lube by moving the arm with the vacuum hose in some light oil. Best way to keep your motor happy is use it at least a few swipes whenever you're driving the car.
Old 02-09-2025, 06:10 PM   #3
nkaminar
nkaminar's Avatar
If the vacuum motors sit for a long while they can become gummed up and corroded. The only solution is to take them apart and rebuild them with new gaskets. If they are still working, spray a light oil or 3-in-one oil where the air goes into the motor and do that while they are operating. Do not use WD-40 as it will evaporate over time.
nkaminar is online now   Reply With Quote
Old 02-09-2025, 08:34 PM   #4
Greg Jones
Greg Jones's Avatar
Maybe I am dense, but how do you spray a light oil into the unit when it is operating?
Old 02-09-2025, 09:28 PM   #5
Fordestes
take the hose loose and work the motor by hand while adding the lube.
Fordestes is offline   Reply With Quote
Old 02-10-2025, 12:36 AM   #6
fourfords
fourfords's Avatar
Add lube exactly where?
fourfords is offline   Reply With Quote
Old 02-10-2025, 04:11 AM   #7
TomInCologne
TomInCologne's Avatar
i put a few drops of fine oil into the vacuum tube connector and the manually moved the wiper back and forth...
TomInCologne is offline   Reply With Quote
Old 02-10-2025, 06:36 AM   #8
nkaminar
nkaminar's Avatar
I forget where the air inlet is. Here is a good article on how to lubricate the motor using a hose: http://modelabasics.com/wiper.htm.
Paul Shinn may have made a video about the motor.
Any excess oil remaining in the motor will be sucked out by the vacuum when operating.
Old 02-10-2025, 10:08 AM   #9
katy
katy's Avatar
Don't need any fancy modern "up to date" windshield wipers. I'll stick with the hand operated one, works every time, variable speed too.
Old 02-10-2025, 12:41 PM   #10
Fullraceflathead
Fullraceflathead's Avatar
Variable speed and intermittent as needed!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-10-2025, 02:52 PM   #11
rotorwrench
rotorwrench's Avatar
The hand wipers were generally only supplied with the light commercial pickups and trucks. Most other cars came with either electric or vacuum wiper motors depending on year of manufacture.
When the on/off valve is placed in the ON function, the vacuum is introduced to the shuttle valve chamber. Two of the ports are already open to allow vacuum to draw the paddle off the park chamber and start the oscillating function. Just before the paddle reaches the opposite side, the shuttle valve rocks over to close off one port and open the opposite port to start the paddle back the other way and so on. When the valve is placed in the OFF position, then the vacuum is stopped to the shuttle chamber and the port is opened to the park chamber which allows the paddle to be drawn back to park position and hopefully seal off on the park seal, that is a part of the paddle, to stop the vacuum draw from the engine.
A lot of folks lube the paddle & chamber with vaseline and then use light oil or even brake fluid. The shaft and oscillating components can then be lubed prior to reassembly when they have it all apart. Some folks use ATF or brake fluid as a lubricant if going the service method route. It's up to the owner on what they want to use but I prefer ATF myself.
Old 02-12-2025, 03:22 PM   #12
BillCNC
BillCNC's Avatar
I was told by the person that I bought mine from to smear a light coat of Vaseline on the bottom bowl surface every few years or when needed.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-22-2025, 07:07 AM   #13
mattgic
mattgic's Avatar
My wiper was not working, so I followed the lubrication advice and it is moving now. My question is: Is the wiper suposed to continuously move? I am having to push the rod in to move it one way, and pull to move it back. Is that the way it is designed?
mattgic is offline   Reply With Quote
Old 03-22-2025, 07:51 AM   #14
nkaminar
nkaminar's Avatar
There is a pneumatic switch that flips back and forth to change the direction of movement. It may just need a little oil. Look at the exploded drawings of the vacuum motor.
Old 03-22-2025, 09:56 AM   #15
old31
Yes, the wiper will continuously move.
Old 03-22-2025, 10:32 AM   #16
rotorwrench
The shuttle valve controls the wiper's constant reversing motions. When the unit is turned off, it should be drawn to the park position.
Old 03-23-2025, 12:12 AM   #17
mass A man
mass A man's Avatar
I use a little smear of NAPA "Sil-Glyde". A silicone grease. Doesn't run, gum or melt.
mass A man is offline   Reply With Quote
