#1 |
I got a 4 barrel manifold out of a barn full of "stuff" a couple weeks ago. No broken bolts, screwed up threads, cracks or other problems that I can see. Now I want to clean it up, paint it and use it, The first step is probably clean the inside, What's the best way to do that?
#2 |
Aluminum or cast iron?
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
#3 |
#4 |
If it is rusty, media blasting is one method. Another is chemical bath. With media blasting, make sure the inside is thoroughly cleaned of media.
Electrolysis is another method which can remove rust and other crud.
#5 |
I’d see if if the local machine shop could hot tank it first. Then I’d go thru that water passages in front with brushes if there’s any rust left. The last thing I’d check is the exhaust crossover if it was set up for the heated choke. The tubes inside tend to rust out. They can be replaced, or capped off, if using an electrical or manual choke. Might even do that before I tanked it. Check the port surfaces with a straight edge, but I’ve not had a problem there with iron manifolds.
#6 | |
1952 Ford F1 !956 Fairlane Club Sedan 1965 Falcon Sprint 2007 Mustang GT |
#7 |
I agree with all the above suggestions. However, many years ago I picked up a nice looking factory Ford medium riser dual quad manifold. Spent hours cleaning and polishing it. When I went drop it into place on the engine I discovered that the sides and lower sealing edges had been machined down roughly .040" each. There was no way the gaskets could seal this thing to the heads. Since this engine was more show than go, I stacked 3 gaskets on each side and lots of silicone on the ends. It worked, no coolant or vacuum leaks, but definitely not the way to go.
So, there are two morals to this story. First, buyer beware and second, I always check the fit of any intake manifold new or used before I spend anytime cleaning and painting. |
#8 | |
![]() Quote:
#9 | ||
![]() Quote:
If it's not a '57+ style ECZ-9425-B or you're doing an earlier year specific restoration it may not be worth the trouble. Last edited by dmsfrr; 02-08-2025 at 08:14 PM. |
#10 |
to keep from burning the paint off u need to get intake manifolds from concours parts which have 'restricted" heat riser ports. concoursparts.com
#11 |
You mean gaskets ??
#12 |
yes I meant intake gaskets.
