Old 02-04-2025, 12:20 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Oil Pump Flow Rate
A question that often arises about the Model A's oil pump is, "What is its flow rate?" The only info I could find is the flow rate is about 1 gallon per minute at a shaft speed of 1300 RPM. This correlates to a crankshaft speed of 2600 RPM, which in high gear with a 3.78:1 differential is a bit over 60 MPH.
Does anyone know of a factory spec for the oil pump's output?
Bob Bidonde
