Old 01-27-2025, 03:12 PM   #1
411Ton
Default What Transmission is this?
I do not know if this is 3 or 4 speed, all I know is the SN matches the frame on this 3/4T 41. To order a rebuild Kit, what transmission do I refer to? Thanks!
411Ton is offline   Reply With Quote
Old 01-27-2025, 03:25 PM   #2
rockfla
rockfla's Avatar
Default Re: What Transmission is this?
Call Mac Van Pelt, Van Pelt Sales. He is "THE" transmission man (Guru really) for parts and or any other transmission questions
1-513-724-9486
Old 01-27-2025, 03:35 PM   #3
TJ
TJ's Avatar
Looks like a big truck 4 speed
Old 01-27-2025, 03:38 PM   #4
411Ton
thanks!
Old 01-27-2025, 04:17 PM   #5
1952henry
1952henry's Avatar
Warner Gear T9, what Ford called a spur gear. It has no synchronizers. It is the same as the one in my 52 MH R32-4 (F3).
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 01-28-2025, 06:39 AM   #6
38 coupe
38 coupe's Avatar
That is the earlier version of the crash-box four speed (no synchros) without the removable clutch housing, frequently called a "hogs head" by the hot rod community. It may be designated a T-8 transmission instead of a T-9, I'm not sure what technicality makes one or the other, as far as I know they are functionally equivalent.
Old 01-28-2025, 06:55 AM   #7
Mac VP
Mac VP's Avatar
Definitely a four speed type…..correct for the 1941 V-8 that it’s attached to. It may have the shifter lever with the little trigger operated reverse lockout release (located just below the shifter knob). The ball bearings, caged roller bearings, paper gaskets, rear oil seal are all available….we try to keep those all in stock. After that, it gets very sketchy on what is available. If your truck was a 1/2 ton pickup I would be suggesting that you change over to the three speed transmission for drive ability and parts availability. Not sure if that is doable with the 1 ton truck. If the gears are still in decent shape, I’d refresh the bearings and use it…..getting used to double clutching on every shift.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 01-28-2025, 10:02 AM   #8
411Ton
thanks for the feedback! It's in a 3/4 Ton truck, certainly is original. will be reaching out for parts, Mac!
Old 01-29-2025, 08:13 AM   #9
richard crow
they make great boat anchors
richard crow is offline   Reply With Quote
Old 02-22-2025, 04:14 PM   #10
Grumpy moose Sam
In my opinion, it looks to be a T9 with a PTO cover on the passenger side
Why brush off both sides of that transmission on the driver side if it says 59T then it’s a 4 speed
Grumpy moose Sam is offline   Reply With Quote
Old 02-22-2025, 06:36 PM   #11
Model51
Model51's Avatar
The serial number stamped on the top lip of the transmission bellhousing flange (above the small removable inspection cover) should provide information on the approximate build date.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 02-22-2025, 07:45 PM   #12
v8fordman
v8fordman's Avatar
You need 2 more of them?
v8fordman is offline   Reply With Quote
