Old 01-27-2025, 03:03 PM   #1
kurt v
Default wiring harness install
Does the switch part of the harness need to be set a certain way so that the prongs on the column line up correctly, can't seem to get the switch right,won't look straight down on the steering wheel ?
thanks kurt
kurt v is offline   Reply With Quote
Old 01-27-2025, 04:38 PM   #2
Bob C
Default Re: wiring harness install
Maybe the spider on the bottom of the horn rod needs to be turned 90 degrees.
Old 01-28-2025, 01:21 PM   #3
kurt v
Needed to turn the spider, last guy had it wrong, never assume.
thanks
