Old 01-08-2025, 06:37 AM   #1
Stingray70
Stingray70's Avatar
Default Trailer towing question
Ok this isn't Model A specific, but I know some of you guys have experience with this.
I have a 2wd Silverado 2500 that I tow my 24' enclosed trailer with. It tows great but the truck does squat a bit even with the trailer loaded properly. This year I will be doing 2 cross country trip with a very heavily loaded trailer (probably 9k lbs).
My question is, are air bags worth the time & cost to install? What about a WD hitch?
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 01-08-2025, 07:57 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Trailer towing question
Best bang for the buck is a weight distributing hitch with torsion bars.
29spcoupe is offline   Reply With Quote
Old 01-08-2025, 08:11 AM   #3
nkaminar
nkaminar's Avatar
As 29 sport coupe said, the weight distributing hitch works well. I use that on my truck when towing my travel trailer.
Old 01-08-2025, 10:55 AM   #4
Phil Brown
Phil Brown's Avatar
Another vote for the weight distributing hitch
Phil Brown is offline   Reply With Quote
Old 01-08-2025, 11:48 AM   #5
Jim Brierley
I used both when towing a tow-behind RV with my F-250 I just used a WD hitch. When I got a 41' 5th wheel I needed air bags. My recommendation for you would be a WD hitch, but if this is a one time tow, go with whichever is cheaper, probably the bags.
Jim Brierley is offline   Reply With Quote
Old 01-08-2025, 01:33 PM   #6
ModelA29
ModelA29's Avatar
WD Hitch - A rule of thumb is 10% of gross weight as tongue weight. The bars come in different tongue weight capacities.
https://www.etrailer.com/dept-pg-Wei...ion_Hitch.aspx
ModelA29 is offline   Reply With Quote
Old 01-09-2025, 02:15 AM   #7
dave in australia
The problem with airbags is they put the load on the wrong spot of the chassis, and that can lead to bent and cracked chassis'. The only time airbags are OK, is if the car has coil springs on the rear, as the coil mount area of the chassis is designed to carry the weight in that area. And also, with 10% of the trailer weight on the towbar, that weight is added to the axle load limit of the cars rear axle.
dave in australia is offline   Reply With Quote
Old 01-09-2025, 04:21 AM   #8
Synchro909
Synchro909's Avatar
Another vote here for a load distributing hitch. My father made one back in the 1960s and amazed other caravanners with how well it worked. I was only a kid but I remember he used two halves of a leaf spring instead of torsion bars.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-09-2025, 09:31 AM   #9
Big hammer
Last summer I moved step daughter 600 miles, 2500 gmc and 7 ft X 22 ft enclosed trailer. Yes the truck squatted a bit, the trailer squatted a bit , trailer was level, the truck was about level maybe a little nose high. Pulling through hills only once did the combination buck at a bridge crossing, later that night I wondered about headlights shining to high but no one flashed their headlights at me. A wild guess was 9000-10000 lbs load. Squatting the spring is normal when you’re loaded, if you need helpers have you overloaded your tow vehicle ? I would recommend not overloading your truck or trailer tires and make sure your brakes are in good condition ! The first 1/2 hour of driving loaded was a little tense, but after getting use to pulling it load it was no problem. Watch out for the other drivers like when you’re driving your model A !
get a bigger hammer tap done
Old 01-09-2025, 12:47 PM   #10
Phil Brown
Phil Brown's Avatar
You need to remember that with a bumper pull style trailer when the rear of the tow vehicle squats down that it is also lifting the front up and removing weight from your steering tires. That's where the load distribution hitch comes in. It's not just to keep the rear from squatting down but transfer that weight towards the front of the tow vehicle giving you back your tire traction for steering.
