#1 |
I just removed my filler pipe on my 1935 ford and replaced the lead washer at the base of the pipe. When I tighen it up, I can't seem to get it tight enough so that the filler pipe does not rotate-reason for the leak I believe. I have a spanner wrench to tighten the collar but am afraid to really crank it down. Should I add another washer or some other thing to take up the space.
#2 |
My neck has a small leak too so I would be interested in answers to this thread. A similar question was asked about this not to long ago and someone said they used an o-ring instead of the lead washer. Don't know. Having tried either as of yet. Where did you get your spanner wrench.
#3 |
i take a punch and tighten mine tight. no leaks yet
#4 |
The spanner wrench is an 34-219 Armstrong ordered from Sears on line-abou $6.00 or so.
#5 |
You might try using a strap wrench or a chain wrench. If you use a chain wrench, put carboard around the filler to keep from scarring the metal.
#6 |
#7 |
I had a leak with my 35 neck - used the proper wrench and did crank it down hard to seat the lead seal. It worked and no leak. It was difficult to get leverage but with effort and patience you can put enough torque into it to seat the lead, I was not concerned about the threads as they are fine thread and appeared to be set up for high load.
#8 |
The threads need to move easy and should be lubricated some, the surfaces that the seal seats on needs to have all remains of old material removed --if there is a lump of old seal, rust etc. it will tighten there and leave other areas loose.
A trial fit without the seal should be used to prove that the threads don't bottom out before they can clamp the seal tight. If the threads are stiff lube them, work in-out, clean off lube(to remove debris), relube. The idea is that by having the threads, and the flange area that the nut contacts lubed, and moving easy in the threads the clamping force on the seal will be increased , it is also helps to not have any movement of the filler neck as you tighten the nut ( have a helper hold it steady and in alignment as you tighten) --rotational movement between the seal and tank or neck can damage it's ability to seal. |
#9 |
Coupe35 ...................
I'm the one who used a 2" O-Ring on my '35 filler pipe. So far, no problems. But, I do use No-Ethanol gasoline ! I also got mine to tighten up with a pair of Channel-Locks. I did not have a spanner wrench. I did clean my threads, as well as I could. MIKE
#10 |
i am finding out that everyones suggestion to clean and then pre fit is the best way for just about everything with threads.
also i used my old spanner wrench for harley-davidson shocks it is like a sizzor and grabs a hole on both sides of the coller, and as mentioned get a helper and i also used a lead mallet on the wrench. so far no leaks. rich |
#11 |
If I can jump in here.....I am putting my 35 back together and have not gotten as far as the filler neck yet but in reading this thread makes me wounder how many of you have modified the neck for better venting and how??
Thanks
______________________________________________ jfc I couldn't repair the brakes, so I adjusted the horn louder.... |
#12 |
I thimk that the 1935 GAS gage requires a NON vented cap for the gage to work IF you are using the original type of tube gage. jmo kc
#13 |
Well with all this information I should be able to get this thing working. As I get older the extension pipe that fits over the ratchet and wrench handles get longer-this is my assistant. Thanks everyone for the info.
#14 |
jfcrash-
I also have a '35 and if you have a chance, modify your tank venting, do it! Send me your email addy (PM is o.k.) and I will forward you some pictures of what I have done. Tom |
