Old 01-06-2025, 10:07 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Engine Should Haves
All Model "A" & "B" engines should be restored with:
>Modern insert type main & connecting rod bearings;
>Modern stainless steel valves, modern one-piece valve guides & adjustable lifters;
>Modern valve seat inserts for all valves;
>Light weight modern pistons;
>Modern multi-viscosity motor oil with a synthetic blend or full synthetic;
>Modern oil seals on the crankshaft;
>New 5.5:1 or 6:1 compression cylinder head;
>Copper cylinder head gasket;
>Stock breaker point ignition;
>Aluminum 2-blade fan or plastic 6-blade fan;
>Leakless water pump with modern press-fit front bearing;
>160F or 180F thermostat;
>New reproduction exhaust manifold;
>Modern fiber or aluminum timing gear;
>Model "B" grind camshaft;
>Lightened flywheel & V8 type clutch;
>Temperature gauge;
>Oil drain plug fitting soldered or brazed to the oil pan so it cannot spin;
>Engine side pans:
>Popout cable clamp mod to avoid taking off the #8 head nut to remove the distributor;
>Edges of all water passages in the cylinder block, cylinder head, the tops & bottoms of cylinders chamfered to remove sharp edges that are crack initiation sites;
>Edges of all stud holes chamfered to remove sharp edges;
>Static & spin balancing of rotating & reciprocating parts;
>Block pressure tested & magnetic particle inspected to detect cracks before rebuilding.
What would you add to the list?
Bob Bidonde
Old 01-06-2025, 11:04 AM   #2
katy
katy's Avatar
Default Re: Engine Should Haves
That's your opinion, others may vary.
Old 01-06-2025, 11:31 AM   #3
alexiskai
alexiskai's Avatar
Lots to object to in this list, but one element folks may not know about is that people are finding the reproduction V8 pressure plates have stiffer springs than they used to, which obviates much of the benefit.
Old 01-06-2025, 12:00 PM   #4
Joe K
Joe K's Avatar
An "improvement" that Ford compensated for by making the pressure plates take advantage of centrifugal force.
Or so reported... Those with experience with both can report their observations.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 01-06-2025, 12:04 PM   #5
kbinde2
kbinde2's Avatar
Wow,, mine has been doing ok so far.., with proper maintenance I think it will be running for a long time to come.
kbinde2 is offline   Reply With Quote
Old 01-06-2025, 01:31 PM   #6
johnneilson
Joe K
So just for information
The V8 pp did have counter weights on the arms to apply more pressure at higher speeds
The Tractor clutch does not have the same counter weights and can have a higher spring rate/preload to compensate
Many vendors sell the tractor style not knowing
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 01-06-2025, 01:40 PM   #7
J Franklin
J Franklin's Avatar
I like my engine mostly stock, but it has an oil & air filter, a brumfield head, ajustable lifters, and automatic advance distributor.
Old 01-06-2025, 01:44 PM   #8
butch chase
Inserts or Babbitt are a personal choice.
only an Aluminum or bronze cam gear
Best brand 509G graphite head gasket.
Full flow oil filter
A centrifugal advance Points style distributor, Model B Ford or the new Super B+
Leave the rear slinger alone. I've yet to see a rear main "seal" that didn't drool oil
you cant balance a model A crank without adding counter weights.
In your heart you know you won't be happy until you have Burtz block kit, head, cam, flywheel an an automatic advance distributor.
butch chase is offline   Reply With Quote
Old 01-06-2025, 01:45 PM   #9
JoeCB
JoeCB's Avatar
Model A engines should have ? >>>> OIL
Joe B
JoeCB is offline   Reply With Quote
Old 01-06-2025, 02:30 PM   #10
alexiskai
alexiskai's Avatar
The point I was trying to make is, no, those with experience with both will not have useful observations. People who have bought reproduction V8 pressure plates recently, including myself, are finding that they respond differently than V8 pressure plates purchased years ago. And I'm talking about the correct plate, the 09A-7563 plate, not the tractor plate. The springs are too stiff. It's possible vendors are using the tractor plate springs in the V8 plate. Notably, the repro plates omit the insulating washer against the springs, so they must be using different springs than the originals.
Old 01-06-2025, 03:56 PM   #11
Chris Haynes
Chris Haynes's Avatar
This longer release arm makes the stiff V8 clutch work easier. https://www.ecklers.com/model-a-ford...8-24346-1.html
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-06-2025, 04:13 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
You tried getting anything from Eckler's/MAC's lately??
Get the longer lever from Bratton's https://www.brattons.com/CLUTCH-RELE...uctinfo/11270/ Cheaper too.
Old 01-06-2025, 04:50 PM   #13
JayJay
Agree re: Mac’s/Eckler’s. They’ve abandoned the Model A market, and I suggest that the Model A market return the favor. Not that they were all that great to begin with.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 01-06-2025, 08:04 PM   #14
nkaminar
nkaminar's Avatar
No comment.
Old 01-06-2025, 08:29 PM   #15
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Counter weights on crank , keep the slinger but use the brass rear main seal.
Dan
dansluck is offline   Reply With Quote
Old 01-06-2025, 09:09 PM   #16
Synchro909
Synchro909's Avatar
Dan
Brass seal??? Do you mean BRONZE thrust ring?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 01-07-2025, 09:12 AM   #17
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
>Temperature gauge;
>Engine side pans:
Bob, not really 'restoring' if you are doing many of those items are you??
I have offered this before but it bears repeating. Insert conversions are not for everyone. I have another one in the shop right now that has an insert bearing failure. Many are often mislead that once a block has been machined for inserts, then the hobbyist can do bearing maintenance in their own garage without the need for a machinist. More often than not, this isn't the case. It is my experiences that properly cast bearings will outlast insert conversions.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-07-2025, 09:25 AM   #18
Flathead
Flathead's Avatar
I like babbitt if properly done. I also like inserts if block is properly machined for them. Both have pros and cons.
Flathead is offline   Reply With Quote
Old 01-07-2025, 09:39 AM   #19
WHN
I agree. Instead of “should”, maybe “I would recommend” would be better.
Happy New Year to everyone.
Enjoy.
WHN is offline   Reply With Quote
Old 01-07-2025, 04:37 PM   #20
2speed
What bearing "maintenance" does one do on an insert bearing motor?
2speed is offline   Reply With Quote
