#1 |
All of the venders appear to sell the same positive to starter battery cable. Snyders is the only one that lists the cable as 2/0. I don't believe that is correct. Can anyone verify if the cables sold are #1 or 1/0?
Thanks, Dave |
#2 |
#1, 19 inches long. Berts has them and brattons.
www.whidbeymodelaclub.com |
#3 |
And try to find the bigger size for a streetrod....nearly impossible.
#4 |
Try Tractor Supply, etc.
#5 |
Can I just say something here....welding cable is not the same thing... Just sayin'.
#6 |
#7 |
Thanks to all that have replied to my question. I have said many times that if you ask ten people the same question you will probably get twenty different answers. Gary WA is the only one that answered my question. I was not asking where to buy one only what gauge are the ones we buy made of.
I consider the Ford Barn to made up of mostly an older generation. I'm 77 so I should fit in to the older generation. Were we not taught to listen or read before we answer. Please people read the entire post before answering. Last edited by Dave1931Pickup; 01-11-2025 at 11:30 AM. |
#8 | |
![]() Quote:
I have used welding cable with no ill effects. But for ease of use you can't beat this place. https://www.batterycablesusa.com/00-...able-with-ends If your car is 6V you'll want the 2/0 - https://www.batterycablesusa.com/battery-cables |
#9 |
#10 |
If they sell it as double aught, it will be.
#11 |
Go to this site https://www.batterycablesusa.com/battery-cables. All the different cable sizes are shown along with a voltage drop calculator for different gauge cable and loads.
I use a 1/0 gauge cable and solder on the connectors versus crimping. |
#12 |
The link that CT Jack provided above is great. The drop calculator they provide calculates the voltage drop with 00 (2/0) cable, 200 amps, 6 volts, 2 feet, at 1% or 0.06 volts (approximately).
#13 |
For those who converted to 12V systems, I recommend you retain the 6V battery cables and all 6V field windings. The 6V wire gauges are larger, so they have less voltage drops.
Bob Bidonde |
