Old 12-27-2024, 09:52 PM   #1
Hoodooman
Default Help troubleshooting miss at all rpms
Hi all, new guy here back again. I have a 52 customline 8ba three on the tree. Before I explain further, I may follow everyone's advice soon and "send the carb to charlie in ny."
I pulled this car out of a barn, but it had run at least 10 years ago. The car had (has) a pertronix ingnitor I in it, the one that is recommended to use with a stock points coil.
I just recently got it running:
- rebuilt 94 carb. i don't recall what kit I used.
- new coil (.6 ohm 6 volt)
- new plug wires and plugs (7mm supression wires)
- new cap/rotor
- new stock style fuel pump
- new gas tank and sending unit
The engine has a bit of a miss and slightly shakes at idle, and all rpms. As rpms increase, the shake gets worse. As if one cylider maybe isn't hitting.
I have spark at all plugs. Could the carb be the culprit? What should I do to continue troubleshooting? I've driven it about 45 miles total and it doesn't seem like it would be down on power, but it's my first time behind the wheel of a flathead. I don't know, but I imagine that it's never been apart and looks to have 122,000 miles on it so its a bit tired.
As you can tell I'm not knowledgeable about flatheads but am here to learn.
Thanks for any help!
UPDATES:
- all valves in engine are moving (doesn't mean they're sealling of course). I verified this with a snake cam.
I did a cold, dry compression test with carb removed and all plugs out. It's not good:
1- 80
2 - 70
3- 75
4- 90 (this is actually the cylinder I thought was the problem because I didn't hear any difference when disconnecting the spark plug wire when it was running)
5 -100
6- 60
7- 70
8 - 85
Afterwards, on #6 I did a wet test and it really didn't change - I saw about 65psi. Maybe a valve isn't sealing?
A wet test on the other low cylinders saw about a 10-15psi change.
I don't have the money to put into this thing. I'm thinking about pulling the intake and head, and trying to look at the #6 valves closer.
52 Ford Customline Fordor
Hoodooman is offline   Reply With Quote
