Old 12-15-2024, 01:38 PM   #1
Hoodooman
Default 94 carb leak at accelerator pump shaft
Hi,
I just rebuilt my original 94 carb which leaked EVERYWHERE. Now, it leaks at the accelerator pump shaft. I set the float to 1 - 11/32. I'm also having trouble with weepage at the bowl drain plugs sometimes. The fiber washers wouldnt seal at all so I used viton o ring seals which totally sealed one plug, and 99% sealed the other.
First timer here with flatheads. How can I seal this thing up?
Secondarily, can I adapt a 2bbl, maybe a webber? I put one on a 54 chev 6 banger once and it worked really well. Not worried at all about originality, just want the car to run well and not leak.
Thanks
52 Ford Customline Fordor
Hoodooman is offline   Reply With Quote
