Old 11-27-2024, 05:54 PM   #1
50Trucking
50Trucking's Avatar
Default Turn Signals
I would like to put turn signals on my A. I reworded it with a new loom but it did have turn signal wires included in the loom. I would like to buy a rocker type turn signal switch like they have on ATV’s and mount on dash. Buy a 6 volt flasher and mount under the dash. Then run wiring to 6volt LED lights mounted on front and rear. I have not been able to find a kit that is 6 volt..
Does anyone out there think it will work and if not how to do it without using the colum mounted switch.
50Trucking is offline   Reply With Quote
