Old 11-24-2024, 01:48 PM   #1
kurt v
Default 31 roadster pass door
My pass door kicks out on the bottom about 5/8", other than that it lines up great and latches fine. Is there a way to adjust the hinges, hinges seem to be fixed and not adjustable. Driver door fits great, body has no shims , just front firewall pads, frame is good. Door is set in at about 3/32' even top to bottom at the hinges can't seem to be able to move them out to fix my problem.
thanks kurt
kurt v is offline   Reply With Quote
Old 11-24-2024, 03:31 PM   #2
Bob C
Default Re: 31 roadster pass door
Has the body spread out at the top?
Old 11-24-2024, 04:34 PM   #3
kurt v
I've tried to pull the rear jam area in with a small come along but something will have to buckle to make it stay. I'll just have to stair at it a while longer and figure a way to shift the hings in and out a little bit.
kurt
Old 11-24-2024, 09:45 PM   #4
Herb Concord Ca
You can try placing a block of wood at the bottom of the body rail and press against the rear bottom of the door, to see if you can move the door closer to the body.
Herb Concord Ca is offline   Reply With Quote
Old 11-24-2024, 10:26 PM   #5
Synchro909
Synchro909's Avatar
Put a block of wood at the top of the door to prevent it from closing, then push the lower corner in. It might take quite a bit of pressure to do it but you will be able to get the bottom corner closer to the body without much trouble. Your aim is to twist the door from its currently incorrect shape to somewhere closer that you are happy with. With cars of this age, VERY often he doors were left with a buckle in them so that when they closed, there was tension on the catch and they didn't rattle and squeak so much so don' t drive yourself crazy trying to get it "perfect".
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 11-25-2024, 11:35 AM   #6
Ray in La Mesa
I've used the "block of wood" procedure a number of times & it works great.
Ray in La Mesa is offline   Reply With Quote
Old 11-25-2024, 11:41 AM   #7
rotorwrench
rotorwrench's Avatar
The 30/31 body has a bit more bracing due to the little package tray that helps hold the quarters together better. It could still get warped a bit in an accident but it can be corrected with proper measurements at certain key points. The doors are small but can get warped along with the hinges and hinge points due to their fragile nature. Tweaking and shimming are the only way to fix them. Comparing to known good fit items would require observing other similar cars for ideas about fit and function.
Old 11-25-2024, 12:33 PM   #8
mcgarrett
In the 1953 Ford Truck factory repair manual there is a photo showing the use of special tools made to "tweek" a door that didn't fit correctly, either from the top or bottom. The wood block method will work the same way but be careful how and where you place the blocks and that you don't over twist it.
mcgarrett is offline   Reply With Quote
Old 11-25-2024, 07:10 PM   #9
Smokedtires
Smokedtires's Avatar
Wow, cool!
Smokedtires is offline   Reply With Quote
Old 11-25-2024, 08:34 PM   #10
mcgarrett
Close examination of the above picture suggests that an enterprising Model A owner could make something similar with some big clamps and a suitable beam out of scrap material to go against the door opening and accomplish the same thing. Seems like that would be a great tool for Model A clubs to have available for their members to borrow.
Old 11-25-2024, 08:41 PM   #11
Karl Wescott
Karl Wescott's Avatar
Before you start tweaking the door, measure the diagonals across the cowl and across the quarter. Each pair (cowl-cowl & quarter-quarter) should be within 1/8" of each other. If more you may have an underlying out of square issue that your efforts would be better spent to address.
Karl Wescott is offline   Reply With Quote
Old 11-25-2024, 08:48 PM   #12
mcgarrett
KW is absolutely right. The basic body geometry has to be right BEFORE any tweeking of the doors themselves.
Old 11-26-2024, 01:43 PM   #13
gdmn852
gdmn852's Avatar
Hello, as mentioned, check the upper quarter panels for cracks and weld , a common place for them to break is near the area where the to moldings are. On the inside of panel, there is an angle that ends and usually cracked here . On my previous roadster, they were incorrectly welded for location, I cut the weld , brought the upper quarter inward and reworked to correct location. The doors do spring out so check that also . I think any unrestored roadster body I’ve seen have cracked at this location.
File Type: jpg 10F5E7AE-9D9C-466B-9AE6-E2C96F4E4B44.jpg (53.4 KB, 32 views)
File Type: jpg 2442AB7B-4191-4191-AC8C-23338F9208F8.jpg (50.4 KB, 32 views)
gdmn852 is offline   Reply With Quote
Old 11-27-2024, 10:32 AM   #14
Planojc
Planojc's Avatar
Had the same problem with my 31 roadster, but after doing the body alignment, the door kick out went away.
Planojc is offline   Reply With Quote
