Old 11-07-2024, 06:58 AM   #1
ScubaChief60
ScubaChief60's Avatar
Default 1935 Fordor - play in steering wheel. Adjustable?
Hello all... in my fine tuning of my '35 restoration... I am now planning to try to tackle some play in my steering wheel which I imagine is from my steering gearbox. It has the John Deere 'corn head grease' in it and works very smoothly. It has about four inches of travel in the steering wheel before anything happens with the steering. I see on top on the gearbox what I am hoping is an adjustment to tighten it all up.
Drag link and tie rods all are perfect with no play. Tie rod ends replaced and alignment done. It drives well but would be much better without any steering wheel play.
But before breaking anything I am asking all of you. Thanks!
ScubaChief60 is offline   Reply With Quote
Old 11-07-2024, 07:24 AM   #2
glennpm
glennpm's Avatar
Default Re: 1935 Fordor - play in steering wheel. Adjustable?
Sounds like you're all set except for the steering box. The two articles attached will help there.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 11-07-2024, 07:50 AM   #3
Terry,OH
Terry,OH's Avatar
The adjustment on top of the box is to eliminate any in or out play of the sector shaft. Depending upon where the play exist in the box there are three adjustments. The one mentioned above. If the column moves up or down the least bit, the adjustment is gaskets between the box and the collar around the bottom of the steering shaft. On the bottom of the box is an adjustment with one off-set wedge that can move the sector closer to the worm. If you have wear in the bearings or races, bushings or metal internal parts. It can be impossible to eliminate all the play, plus a small amount of play in the center of the steering is good.
Old 11-07-2024, 08:02 AM   #4
ScubaChief60
You all are the best! I will attempt the adjustemnts today and will respond with results. Have a great day!
Old 11-07-2024, 11:19 AM   #5
ScubaChief60
In a few words it worked and is great now. Very little play.
Made the adjustment by lifting both front wheels off the ground,
dropping the drag link by the connection to the Pittman arm,
then spinning the steering wheel all the way to the left to dead stop and then just a bit back to the right,
tightened the adjusting screw clockwise just a bit and reassembled.
It is so much better. Just had a great test ride about five miles.
Mission accomplished
Old 11-07-2024, 12:40 PM   #6
glennpm
glennpm's Avatar
Good!
