Old 11-01-2024, 03:44 PM   #1
CallMeSki
Question 1931 Coupe Borg Warner Question.
1931 with a Borg-Warner Overdrive. Could one of you experts take a look at the picture and tell me why there would be a blob of silicone sealant on the end of the transmission? New to model As and to this forum, so please be patient if this is a dumb question.
CallMeSki is offline   Reply With Quote
Old 11-01-2024, 04:14 PM   #2
mcgarrett
Default Re: 1931 Coupe Borg Warner Question.
No dumb questions here...we're all still learning what we thought we already knew!
The silicone blob was likely applied to stop leaks where the gear shaft ends are exposed at the rear of the housing. If it's not leaking now, I would leave it alone and address it only if starts leaking.
mcgarrett is offline   Reply With Quote
Old 11-01-2024, 04:28 PM   #3
Tom Endy
Tom Endy's Avatar
Most of the suppliers sell a device that fits over the ends of the two shafts. It is a small casting that attaches with the single bolt that retains the shafts. It serves the same purpose as the blob but looks a lot better.
Bratton's part number 10500 $18.25
It has nothing to do with A Borg Warner overdrive.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 11-01-2024, 04:32 PM   #4
Gene F
Gene F's Avatar
Someone wanted to save a few bucks... Of course the trans grease MAY have leaked down that far.
Gene F is offline   Reply With Quote
Old 11-01-2024, 05:29 PM   #5
CallMeSki
That is exactly what I needed to know. Thanks everyone!
Old 11-01-2024, 05:35 PM   #6
mcgarrett
One more thing...the correct lube for the BW overdrive is 30 wt. engine oil. There are 2 fill locations in that transmission. One for the transmission gearbox itself, and one for the overdrive unit. Be SURE you have the proper oil level in BOTH sumps!
Old 11-01-2024, 06:01 PM   #7
Tom Endy
Tom Endy's Avatar
Borg Warner overdrives are notorious for leaking the overdrive oil into the differential. The reason is all the BW's are cottage industry modification and the rear seal used is a grease seal, not an oil seal and the oil gets past it. It is prudent to check the oil level in the differential every few hundred miles to see if it is manufacturing oil. If it is, three things are likely happen.
1. You will not become a rich oil baron.
2.Oil will overflow the differential out to the brakes.
3. However, before that happens the overdrive will starve for oil and fail.
Tom Endy
