Old 10-27-2024, 06:38 PM   #1
grgrywils
Default 30 Coupe will stall after a restart
Yo Fellow A's, Here is my scenario. Motor has 1500 miles timing is correct have had two different rebuilt carbs, one a B carb the other a Standard Zenith same problem. Start up in the morning head to the coffee shop 15 minutes away. restart a hour or two later with control lever down and idle lever in place just like I ran car. warm up briefly take off get to light or stop sign and she stall as if it ran out of fuel do a restart with a little trouble get going then she seems to be fine the rest of the way. do you think my Control lever placement has something to do with it? I doubt it's the carburetors fault I think it"s some kind of Pilot error. GW
grgrywils is offline   Reply With Quote
Old 10-27-2024, 06:52 PM   #2
gdmn852
gdmn852's Avatar
Default Re: 30 Coupe will stall after a restart
Check wire inside of distributor,sometimes they loosen up and short out , I would start there first .Moving the spark control sometimes will make it short out depending on positioning.
gdmn852 is offline   Reply With Quote
Old 10-27-2024, 07:00 PM   #3
Bob C
Is the control lever the spark lever and the idle lever the throttle?
The spark lever should be up when you start the engine.
Old 10-27-2024, 07:05 PM   #4
gdmn852
gdmn852's Avatar
Also spark control should be up position, retarted for starting, advance no more than about half way after starting, depending on road conditions.
Old 10-27-2024, 07:06 PM   #5
1crosscut
1crosscut's Avatar
What is your fuel line set up? Does the fuel line run down hill all the way to the carburetor or does it dip down and then go up to the carburetor. Weird but I've found that the Model A runs better with the fuel line sloping down all the way to the carburetor as it came from the factory.
Do you have one of the plastic in line fuel filters spliced into the gas line?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-27-2024, 08:40 PM   #6
CT Jack
CT Jack's Avatar
Check the float shutoff valve in the carburetor to make cetain it is clean, sealing and releasing properly. Check the float level and reset if necessay. The fuel level is supposed to be 5/8" below the bowl gasket surface. If the fuel level is too low the engine will be starved for fuel. Check Les Andrew's manual for how to set float.
CT Jack is offline   Reply With Quote
Old 10-28-2024, 03:42 AM   #7
grgrywils
thanks I will check this
Old 10-28-2024, 03:43 AM   #8
grgrywils
Yes, and I will do this and see. thanks
Old 10-28-2024, 03:46 AM   #9
grgrywils
No inline plastic filters, same fuel line set up as my 29 Tudor. thanks for your comment.
Old 10-28-2024, 03:48 AM   #10
grgrywils
will check, thanks A Guys for your comments I'll get it too it and see what comes up. GW
Old 10-28-2024, 04:33 AM   #11
ronn
when you restart the car after an hour, both levers up and as if starting first thing in the morning.
I dont run my chainsaw an hour after using it wo resetting the choke and starting fresh as if first start of the day.
Old 10-28-2024, 08:44 PM   #12
Rob Doe
Does the engine die at other stop signs or just a specific stop light? Stalling at stops is a common affliction of the Zenith carb.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 10-29-2024, 05:38 AM   #13
ronn
also an affliction of my 2012 f250, as of late...........Ford............ ugh
Old 10-29-2024, 06:05 AM   #14
Marshall V. Daut
Ensure that the gas cap vent is clear. Also ensure that you don't have a radiator cap on the gas tank's neck. The fit is interchangeable between the two, but the function is not. The gas cap MUST be vented in order for the gravity fuel feed design to function. Air has to be able to enter the gas tank via the cap's vent hole in order for the fuel to flow unhindered to the carb. Otherwise, you will experience fuel starvation, especially when the ambient temperature is hot and the engine warmed up.
Marshall
Marshall V. Daut is online now   Reply With Quote
