Old 10-15-2024, 02:27 PM   #1
Pamlico
Pamlico's Avatar
Default 58 Ford Ranchero manual steering box pitman arm
Well, the manual steering box just gave up on my Ranchero. It was the roller bearings on the long shaft. Luckily, and I truly mean luckily, it gave out right in front of my garage upon returning from a cruise-in. It had been acting up and had a lot of play for a while and I had adjusted the pitman shaft all I could. In anticipation of this impending failure, I found a used 58 steering box at Carlisle in June. Fast forward to today and I am in the throws of making the swap. I noticed the pitman arm on the replacement box is about a half inch longer than the original one. I could easily use my old one but I am wondering, while I'm there, is there an advantage to using the slightly longer one? Better ratio(or not). And would that require a front end alignment, etc? Thanks!
Pamlico is offline   Reply With Quote
