Old 10-05-2024, 08:14 PM   #1
Tom Bellfoy
Tom Bellfoy's Avatar
Default recommended current through 6 volt coil primary
Can anyone tell me what the recommended current (amps) should be running through a 6 volt ignition coil primary circuit in order to provide long life on ignition points on a model A ford. I can calculate the resistance just need the suggested amps
Tom Bellfoy is offline   Reply With Quote
