#1 |
I need new front shoes on my 32 highboy. I run 46 to 48 hydraulic brakes.
These ones seam the most reasonable. Wonder what the quality is. I am sure from China https://www.ebay.com/itm/12668132616...Bk9SR-rrpY3LZA |
#2 |
Go and check 3rd Gen Automotive,Michael is on here and super guy to deal with .
#3 |
When it was time to do the first brake job on my '51, I found that it had Ford Script brake shoes. I thought it was pretty cool, and decided to send them out to have new linings riveted on. I have not regretted my decision.
#4 |
#5 |
This company will reline original brakes and arc them to drum diameter.
I just sent a pair of shoes to be arced and got one day turn around. https://brakeandequipment.com Call and ask for shop. John
Welcome each day |
#6 | |
Good to know, thanks
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source-for-the-1932-thru-1953-Flathead-Ford |
#7 | |
![]() Quote:
Been using Brake & Equip for parts and shoe lining since the mid '70s; never a problem. |
#8 |
I followed the link, and recognize that company. They are the folks that I had reline my shoes back when. I also had them sleeve the master cylinder in my Corvette. Highly recommended.
#9 |
Well I just installed shoes from O Reillys auto. 39.99. They looked fine but when installed only one lined up with the brake cylinder piston. Two I could live with and one barely touched the piston. So I am going to return these and go another route. Probably third gen
#10 |
With that vintage brake shoes, I would re-line the last set that worked.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
#11 |
With the experience I had with the last set of "new" brake shoes I bought from a dealer, I agree with this. (The web on on the shoes was too thick to fit into the wheel cylinder pins and I had to grind them down.)
