#1 |
We are installing a NuRex 'pop-out-look-alike' ignition switch and using their armoured flex cable into the distributor, but because we are installing an electric fuel pump for some 97s, I need to change the wiring somewhat and eliminate the pop-out switch. Has someone already made a picture diagram or schematic showing the modified wiring that I can print instead of taking the time to make one??
TIA!! |
