#1 |
I have 2 questions, what is the small button for that is under the starter button, on the bottom of the dash? 2nd ? Should the starter engage even with the key off and if it shouldn’t, what could be that problem?
#2 |
Without seeing a picture I'd say dash light dimmer switch for your first question. If you hit the starter button with the key off it will turn the engine over but not start.
#3 |
Thank you, that’s what I thought, just wanted to be sure. Under the starter button there is a smaller button and a small knob that would seem to be a dimmer.
#4 |
I don't know what a push button would be doing down there. This is a link to the 1946 through 1948 Mercury electrical diagram but it doesn't include accessories that may have been mounted. http://www.vanpeltsales.com/FH_web/F...946-48merc.jpg |
