Old 09-17-2024, 04:30 PM   #1
Panheadguy
Smile Model A Mech brakes on '40 rear axle?
Try not to laugh. For reasons of my own I am considering putting an open or torque tube '40 rear axle under my Model A but want to retain the 4 wheel mechanical brakes. I am aware of the torque tube mods that need to happen.
Soooo, why wouldn't it work when hydraulics can be adapted to model A....I'm just going the other way!
Fire away!
Panheadguy is offline   Reply With Quote
Old 09-17-2024, 05:30 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Model A Mech brakes on '40 rear axle?
As long as suspension for the rear moves in the same arc as the rods so the center to center distances for the brake shafts stays constant with suspension movements.
Old 09-17-2024, 07:10 PM   #3
shiver
Anything is possible..should you do it? Up to you
shiver is offline   Reply With Quote
Old 09-17-2024, 08:57 PM   #4
DJ S
DJ S's Avatar
What are the advantages of a ‘40 rear axle?
DJ S is offline   Reply With Quote
Old 09-17-2024, 09:16 PM   #5
johnneilson
More than likely it will be about 2" wider than the Model A rearend.
Make sure tires/wheels fit as you like.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 09-18-2024, 07:27 AM   #6
Panheadguy
Better pinion support in differential. I randomly picked 1940 as all the later banjo's are pretty much the same inside
Old 09-18-2024, 08:48 AM   #7
mcgarrett
A few important modifications will have to be made unless you have another angle to achieve them. The '40 torque tube and drive shaft will need to be shortened or parts interchanged to make it fit a Model A. Also, spring perches will have to be made/modified for the '40 axle to ride under the stock Model A spring pack. There may be more, but those are the ones that come to mind right off.
mcgarrett is offline   Reply With Quote
