Old 09-13-2024, 12:34 PM   #1
rfitzpatrick
Default Incandescent Verses LED
Are there any 6 volt LED's that gives off that yellow glow that Incandescent bulbs do?
TKS
rfitzpatrick is offline   Reply With Quote
Old 09-13-2024, 01:25 PM   #2
Bob Johnson
Bob Johnson's Avatar
Default Re: Incandescent Verses LED
Check Ebay. There are lots of places selling them. Or try this link:
https://www.ledlight.com/led-headlig...polarized.aspx
Bob Johnson is offline   Reply With Quote
Old 09-13-2024, 01:28 PM   #3
Harpkatt
Harpkatt's Avatar
If you look at my avatar photo those are LED. Not exact to incandescent but considerably less amperage. I believe they were purchased from LEDlight.com
Part number 78989 there are two options for color,these are warm white.
I would advise getting an extra in case you burn one out which did happen when I moved them to a 12v car. Which...makes sense since they're for 12V. Oops
I have since replaced with the focused beam bulbs though,they definitely make driving better but don't look as good. Both had flicker, focused beams are worse. Very likely a grounding issue that could easily be fixed. I run 6V pos ground
Harpkatt is offline   Reply With Quote
