#1 |
Hey everyone, restoration is progressing slowly on my '40 Fordor Deluxe. But getting there bit by bit, much more difficult than my 1944 Ford GPW Jeep, that's for sure! I have some questions on a few things.
B Pillar Rubber? On the either inside sides of both B Pillars, there's a playable material in a track. The windlace was stabled/nailed into this. It somewhat appears like rubber, but also wood at other times. It's also along the rear door frame on the body. (See photos below) Does anyone know of any repro places selling this or perhaps alternative materials I could get at Home Depot/Lowes? ![]() ![]() Package Tray: My package tray 'cardboard' is the typical super fragile breaking apart. Thankfully, I was able to piece most of it back together to get a template. What are you all using for package tray replacements? A thick cardboard? Same goes with some of the cardboard fabric barriers that are along the back between the quarter window and the rear window. ![]() Front Window Dividers: The polished rustless steel division bars on the front windows between the front window and the vent window... I believe they are 01A-7022296 and 01A-7022297 in Mike's book. When I hunt for those two numbers online, 296 comes up as rubber vent window edge seals. 297 does not exist. Are these made reproduction at all? I might be able to polish mine up enough to be usable, but they have a LOT of scratches. If they are not reproduced, then I might be stuck trying to clean them up. Mike's book does not mention them to be chrome (page 1-33), so I assume they were just stainless steel? And were there any rubber vent window edge seals? ![]() Upholstery: I'm still running into a lot of walls with the upholstery. I'm really sad that I just missed out on the two largest upholstery companies for vintage Fords closing up shop. I've got the headliner figured out (and sourced an exact replica matched to my original 1940 fabric swatches page), and I've already got new windlace that's a 90% match. My rear seats are in decent shape, but the armrests are a different fabric (looks modern replacement that has the same texture, but the color is way off). The front seat has a large rip in the driver's area. I could just patch that closed, but I might have to eventually replace it as it's getting old. The big one is the door panel upholstery and the B pillar upholstery. I only have two matching door upholstery panels (the fabric), and the B pillars and 1 door match, which I think are modern replacements. Then there's the final door that doesn't match anything. So to get all the doors to look similar (and since 2 of the four are missing the 'carpet' at the bottom of the door.. I'm open to any suggestions. Any thoughts on where I might be able to either source fabric or buy any sort of kit for: - Door Panel Fabric/Bottom Carpet - Rear Seat & Rear armrests/Front Seat - B Pillars ![]()
1940 Ford DeLuxe Fordor Sedan 1944 GPW Jeep |
