Old 08-15-2024, 05:14 PM   #1
soonersace
Default Rear differential fluid 55 Bird
I have a slight leak in my 55 tbird differential.
What fluid should I put in there? Regular transmission fluid?
soonersace is offline   Reply With Quote
Old 08-15-2024, 05:29 PM   #2
RKS.PA
RKS.PA's Avatar
Default Re: Rear differential fluid 55 Bird
I use 80W-90 Valvoline...non synthetic in my '56. It's GL 4&5. Don't use ATF!!
Where's your leak...around the pinion seal??
RKS.PA is offline   Reply With Quote
Old 08-15-2024, 11:24 PM   #3
miker98038
miker98038's Avatar
Same rear end, a Dana. Same oil should be fine. Unless someone fitted a limited slip, then I’d have to go check if there’s a difference. I can’t remember from when I put the limited slip in mine.
miker98038 is offline   Reply With Quote
Old 08-16-2024, 10:46 AM   #4
rotorwrench
rotorwrench's Avatar
Any SAE 85/90 GL5 will work just fine in the old Dana 44s.
