Old 08-02-2024, 09:25 PM   #1
soonersace
Default Help identify Hydraulic Brake Upgrade
I have a 34 Cabriolet I’ve had for a couple years. It was all fixed up before I got it. I have 16” Kelsey hays rims and tires.
I’m a mechanical idiot, but I’m slowly learning.
It has a hydraulic brake upgrade and i would like some help identifying it. I just got my kingpins replaced and the mechanic was asking what the hubs were as they do not have a seal.
So my questions are…
Does anyone know what hydraulic brake system was used to replace my original brakes?
Should there be a seal in the hub?
How thick should my brake pads be? These are 5mm and seem fine-
Is there anything else missing here? I did remove the pin from the wheel nut. I removed that before I took the photo.
Thank you in advance-
soonersace is offline   Reply With Quote
