#1 |
If timing is a contributor to overheating, does it need more advance or less…?
#2 |
I believe you want to retard it (less advance) to cool it down but hopefully someone will confirm because I have the same question. So, bump!
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
#3 |
Typically retarded timing is a contributor to excess heating. Advancing ignition timing to proper spec or in some cases slightly more can help. However, it's more often cooling system related, and in most cases the radiator.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" ![]() |
#4 |
retarded timing causes more heat.
#5 |
Yes, retarded timing is not good. It should be checked as it is a very common cause of overheating.
#6 |
#7 | |
![]() Quote:
Great way to remember this!
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source-for-the-1932-thru-1953-Flathead-Ford |
#8 |
Also, late timing decreases engine speed so fuel is increased to compensate. More fuel, more heat.
#9 |
GB's got it, retarded timing has more cylinder exposed to absorb heat
#10 |
Thanks everyone. Clearly I was wrong!
