Old 07-20-2024, 07:32 AM   #1
1931 flamingo
1931 flamingo's Avatar
Default Genesis charger
This is the 2nd Genesis I've had that won't switch to 6V. About 2 years old and used about 3 times.
Any thoughts?
Paul in CT
Old 07-20-2024, 08:54 AM   #2
katy
katy's Avatar
Default Re: Genesis charger
Genesis or genius (Noco) charger?
Old 07-20-2024, 09:10 AM   #3
Tinbasher
Tinbasher's Avatar
I had the same problem. I found I didn't hold the button down long enough for it to switch over. (almost 30 seconds).
Give it a try.
Tinbasher is offline   Reply With Quote
Old 07-20-2024, 01:31 PM   #4
mcgarrett
Sounds like it's time to make an Exodus from the Genesis!
mcgarrett is offline   Reply With Quote
Old 07-20-2024, 04:59 PM   #5
1931 flamingo
I believe it's the genius. I have held it longer than 3 sec.
Paul in CT
Old 07-21-2024, 05:51 PM   #6
flaw'd
Mine works great. As stated, hold down for longer than three seconds. You can also recheck with a volt meter to verify.
flaw'd is offline   Reply With Quote
